Add to basket error
subash
Add to basket error
Post by subash » 02 Feb 2023, 07:03
Hi
"php": "^8.0.10", "aimeos/ai-payments": "^2022.10","aimeos/aimeos-laravel": "^2022.10",
"laravel/framework": "^9.2", "omnipay/stripe": "^3.2", OS: Linux
When we click on add to basket button, we are getting 419 error, but it's working after we logged to the portal. this issue happens randomly when without logging in. please assist me with this. attached is the screenshot. Thank you
419error
419error
addtobasketerror
addtobasketerror
addtobasket
addtobasket
Re: Add to basket error
Post by aimeos » 02 Feb 2023, 08:29
HTTP status 419 is used by Laravel to indicate that the CSRF token is not sent or invalid.
Did you change the template?
subash
Post by subash » 02 Feb 2023, 08:43
I didn't change the template, but it happens before log in on randomly.
Post by aimeos » 02 Feb 2023, 08:47
Most likely, an old CSRF token is sent to the server when adding a product to the basket. Caching could be a problem and you can disable it in your ./config/shop.php ("madmin" section) for testing.
subash
Post by subash » 02 Feb 2023, 08:59
if I disable madmin section, no error is appearing but the site loses performance. Thank you
Post by aimeos » 02 Feb 2023, 10:12
Found the problem (a wrong key for replacing the CSRF tokens). Can you please install the -dev version, enable caching and test again?
composer req aimeos/ai-client-html:2022.10.x-dev
subash
Post by subash » 02 Feb 2023, 10:46
Thank you! its working now
