how to modify helper
mahammadareef
Post by mahammadareef » 03 Feb 2023, 15:56
I wanted to modify this helper file which is inside the vendor directory which contains the standard class
ai-client-html\src\Base\View\Helper\Image
want to modify transform() method of Standard class in image file
Re: how to modify helper
Post by aimeos » 06 Feb 2023, 12:22
It's a bit difficult to overwrite existing view helpers. Instead, create a new one with a different name (e.g. "myimage") and use it in your templates ("$this->myimage(...)").
