One page checkout form action missing
kdim95
Post by kdim95 » 06 Feb 2023, 19:58
Laravel framework version: 9.50.2
PHP Version: 8.2.1
Environment: Linux
I want to have my one page checkout arranged like this, but the form action goes missing if I try to change the order via the subparts. I tried to forcefully set the standardUrlNext in the template, but it didn't work out. What happens right now is that it's always stuck on the same checkout window, everything is filled out, but I can't proceed forward with the checkout. How can I make this work?
'client' => [
	'html' => [
		'checkout' => [
			'standard' => [
				'onepage' => [ 'address', 'delivery', 'payment', 'summary' ],
				'subparts' => [
					'summary',
					'delivery',
					'address',
					'payment',
Re: One page checkout form action missing
Post by aimeos » 09 Feb 2023, 07:52
The problem is that you overwrite the subparts. Remove that configuration and it should work because you've removed also the "process" subpart with your settings.
kdim95
Post by kdim95 » 26 Feb 2023, 21:21
I wanted to rearrange the subparts, I just had to add the 'process' subpart, that seems to have been the issue.
'client' => [
	'html' => [
		'checkout' => [
			'standard' => [
				'subparts' => [
					'summary',
					'delivery',
					'address',
					'payment',
					'process'
