Skip Cart popup
WebcreationUK
Skip Cart popup
Post by WebcreationUK » 07 Feb 2023, 12:18
Hi Team,
I am using Aimeos. I need to skip the cart popup i.e whenever user clicks on add to basket, it should redirect to /shop/basket page instead of showing a popup first.
How is that possible?
Re: Skip Cart popup
Post by aimeos » 07 Feb 2023, 14:37
You can overwrite this JS method in your own JS file:
https://github.com/aimeos/ai-client-htm ... #L359-L378
How to overwrite JS methods is documented here:
https://aimeos.org/docs/latest/frontend ... javascript
