Language Customization
briajer
Post by briajer » 08 Feb 2023, 16:09
My store is using the default 'EN' language and things are mostly fine but I would like to change some words like
'VAT' instead of 'Tax' and 'Title' instead of 'Salutation' as well as a few others like Shipping / Delivery
I have found the en.po file in /ai-client-html/i18n/
This seems to have VAT referenced already but the store isn't using it.
What do you suggest changing?
Re: Language Customization
Post by aimeos » 10 Feb 2023, 08:15
Guess, you are using Laravel, don't you?
In that case, you can find the docs how to overwrite translations here:
https://aimeos.org/docs/latest/laravel/ ... anslations
The easiest way is to add them to your ./config/shop.php file. The PO files are only sources but not directly used and they must be translated to a binary MO file before their content will be used.
