jsonapi reveals sensitive information about the database structure
kdim95
Post by kdim95 » 10 Feb 2023, 12:44
Laravel framework version: 9.50.2
PHP Version: 8.2.1
Environment: Linux
When using the jsonapi, if there is an error, Aimeos reveals sensitive information about the database, like column names and queries. Is there any intended way to hide this kind of SQL output?
Re: jsonapi reveals sensitive information about the database structure
Post by aimeos » 10 Feb 2023, 13:13
The database schema is well known and the revealed data is always only your own or can be retrieved by other endpoints. Thus, the revealed information isn't really sensitive.
Nevertheless, it's always good practice to reveal as less data as possible. We've added a change to 2022.10.x-dev that hides that kind of data and logs it to the DB instead. You can try yourself by installing the -dev version:
composer req aimeos/ai-client-jsonapi:2022.10.x-dev
kdim95
Post by kdim95 » 17 Feb 2023, 11:29
Thank you, that seems to work!
