Property vs Attribute
tblanchard
I'm confused as to the difference.
Trying to import some products, need to create a product type with a set of descriptive flags like "is_for_kids", as well as a set of dimensions that are kind of unusual and then I have color variants as well.
Are these attributes, or properties?
I also find the admin UI really clumsy for trying to define this stuff and find myself using a database table editor more and more but that's maybe another issue.
I have build a shop on Solidus before and properties were things like color so I'm hoping this is similar.
Re: Property vs Attribute
Properties are not shared between products, attributes are and can build a filter in the frontend.
Dimensions are always properties because they are unique for each product. The "is_for_kids" may be an attribute if you want to allow the customers to filter products by its values.tblanchard wrote: 14 Feb 2023, 11:03 Trying to import some products, need to create a product type with a set of descriptive flags like "is_for_kids", as well as a set of dimensions that are kind of unusual and then I have color variants as well.
The UI is built for flexibility and giant amounts of data. If you only need to show a limited set of attributes, you can overwrite the template of the sub-panel and display a few multi-select boxes instead.tblanchard wrote: 14 Feb 2023, 11:03 I also find the admin UI really clumsy for trying to define this stuff and find myself using a database table editor more and more but that's maybe another issue.
Seems like properties in Solidus are named attributes in Aimeos.tblanchard wrote: 14 Feb 2023, 11:03 I have build a shop on Solidus before and properties were things like color so I'm hoping this is similar.
Hello, please how can I add new product types, which I take are "properties" in Aimeos.
I want to add "vendors" to my product list and want to define a type for it.
Thanks in anticipation!
What do you mean "not shared between products"? Do you mean a property key or a property value?aimeos wrote: 15 Feb 2023, 07:58 Properties are not shared between products, attributes are and can build a filter in the frontend.
Can you give an example please?
The property value isn't shared between products but each product can have properties of the same type. A good example are ISBN number of books or EAN codes of products (if not used as SKU).
