Product import: select article with variant - hidden default
Hi Aimeos-Team,
is it possible to hide (product.status: 2) a default product to not shown in shop/search, but useable as a variant in a select product?
I´ve testet with product.status = 2 but at the variant under selection article, the field Status is empty.
If I changed it manually in backend to active (1), the status of the default product changed also to active.
Is this behaviour normal or a bug?
Another chase is, if we would deactivate a variant but not the default product, that is´nt possible now.
Can we separate the product.status of the variant from the hidden-status of corresponding default product?
Only if the default product is´nt available (inactive, check, archived) then the variant is in the same status.
If default product is hidden, the variant status does not change.
TYPO 11.5.22, Aimeos 22.10.4
Thank you!
Ralf
Thank you!
Ralf
Thanks a lot!
Re: Product import: select article with variant - hidden default
Use product.status:1 but don't assign it to any category.heural wrote: 16 Feb 2023, 07:52 is it possible to hide (product.status: 2) a default product to not shown in shop/search, but useable as a variant in a select product?
product.status:2 (hidden) doesn't make sense for variant articles because usually, they are not visible in the frontend at all because they are not assigned to any category. Therefore, this status isn't available there.heural wrote: 16 Feb 2023, 07:52 I´ve testet with product.status = 2 but at the variant under selection article, the field Status is empty.
It's possible by setting the status of the mshop_product_list record to 0 but the admin backend doesn't allow that yet. You would have to change the product selection template for the admin interface and add a drop-down for the product.lists.status field.heural wrote: 16 Feb 2023, 07:52 Another chase is, if we would deactivate a variant but not the default product, that is´nt possible now.
Thank you, that was helpful.
I´ve override the admin item-selection-template and changed the status select field from product.status to product.lists.status.
In import with setting the status of the default product to hidden and variant to active, the backend shows the status correctly.
Thanks a lot!
