Set decimals and precision
loeffe1
Post by loeffe1 » 17 Feb 2023, 11:34
This doesn't seem to be working:
plugin.tx_aimeos {
  settings {
    client {
      html {
        common {
          format {
            decimals = 0
            seperatorDecimal = ,
            seperator1000 = .
Re: Set decimals and precision
Post by aimeos » 19 Feb 2023, 10:31
You can change the number format to an explicit one (not based on locale) if you overwrite the Number view helper with the Standard version here:
https://github.com/aimeos/aimeos-typo3/ ... #L181-L204
Here's described how you can overwrite view helpers in TYPO3:
https://aimeos.org/docs/latest/typo3/ex ... iew-helper
This class must be used instead:
https://github.com/aimeos/aimeos-base/b ... andard.php
