Multiple files for "Downloads"?
rowild
Post by rowild » 27 Feb 2023, 11:48
Is it possible to provide more than 1 file in a shop that sells digital goods? Currently it seems I can only overwrite files, even though the checkbox for "Replace file" is not active...
Maybe I misunderstand the functionality here?
Re: Multiple files for "Downloads"?
Post by aimeos » 02 Mar 2023, 08:41
Currently, only one file for digital downloads is supported. If you have more than one file for download, zip them together in an archive which can be downloaded as single file.
