Can not install Aimeos-Laravel package in fresh Laravel 5.1
sonnguyen
Post by sonnguyen » 03 Nov 2015, 07:06
I have read guide at https://aimeos.org/docs/Laravel/Install_Aimeos and process step by step but get error in order install aimeos-laravel in fresh Laravel 5.1.
Can you help me clear my mistake?
RM-PROs-MacBook-Pro:aimeos1 rm-pro$ php artisan vendor:publish
Copied Directory [/vendor/aimeos/aimeos-laravel/src/database/migrations] To [/database/migrations]
Copied Directory [/vendor/aimeos/aimeos-laravel/src/views] To [/resources/views/vendor/shop]
Copied Directory [/vendor/aimeos/aimeos-laravel/public] To [/public/packages/aimeos/shop]
Publishing complete for tag []!
RM-PROs-MacBook-Pro:aimeos1 rm-pro$ php artisan migrate
Nothing to migrate.
RM-PROs-MacBook-Pro:aimeos1 rm-pro$ php artisan aimeos:setup --option=setup/default/demo:1
  [MW_DB_Exception]
  SQLSTATE[HY000] [2002] No such file or directory
Re: Can not install Aimeos-Laravel package in fresh Laravel
Post by aimeos » 03 Nov 2015, 08:57
I think you've used "localhost" as host parameter which causes MySQL to try Unix domain sockets first. But it seems there's no socket in the standard location (usually /var/lib/mysql/mysql.sock). Please try "127.0.0.1" instead which enforces using TCP/IP.
sonnguyen
Post by sonnguyen » 03 Nov 2015, 09:33
Thanks for quick reply and great tip. It worked!
