Disable force-search not working
PedroLópezAndradas
Post by PedroLópezAndradas » 09 Mar 2023, 09:15
Hi!
I'm trying to diable force-search on aimeos_head_search section.
I have tried setting force-search to "0" on:
client/html/catalog/filter/tree/force-search
and on
client/html/catalog/filter/search/force-search
But when I'm on a category, search results are always from that category instead of full catalogue.
It happens even when I override search-body.php template and set $enforce = false
Maybe I'm missing something?
Thanks!
Re: Disable force-search not working
Post by aimeos » 10 Mar 2023, 09:22
PedroLópezAndradas wrote: 09 Mar 2023, 09:15 I'm trying to diable force-search on aimeos_head_search section.
and on
It's this setting:
And in ./config/shop.php:
	'client' => [
		'html' => [
			'catalog' => [
				'filter' => [
					'search' => [
						'force-search' => true,
See here for reference:
https://aimeos.org/docs/latest/laravel/ ... figuration
PedroLópezAndradas wrote: 09 Mar 2023, 09:15 It happens even when I override search-body.php template and set $enforce = false
It will do the same but you have another template you overwrite in your project.
PedroLópezAndradas
Post by PedroLópezAndradas » 10 Mar 2023, 09:44
Hi @aimeos, thank you for your help.
I've removed all the templates that I had overrided, and it still is searching only on current category.
	'client' => [
		'html' => [
			'catalog' => [
				'filter' => [
					'search' => [
					'tree' => [
Post by aimeos » 10 Mar 2023, 09:49
In that case it's "client/html/catalog/filter/tree/force-search" which must be FALSE.
PedroLópezAndradas
Post by PedroLópezAndradas » 15 Mar 2023, 10:15
Dear aimeos, thank you for your help.
I've tested all possible combinations, and the behaviour is just the same.
When inside a category, pressing search button adds the query to de current category url:
https://midomain.xxx/shop/category~40?f_search=mammo
And the result are obviously empty. :?
Is that the expected behaviour? I think it should search on full shop, like:
https://midomain.xxx/shop/?f_search=mammo
Thanks.
Post by aimeos » 17 Mar 2023, 14:53
If you overwrite this template and remove adding parameters at all, it may work as you want:
https://github.com/aimeos/ai-client-htm ... dy.php#L83
The two options are only for including the f_search resp. f_catid/f_name parameters in the URL or POST when searching.
PedroLópezAndradas
Post by PedroLópezAndradas » 29 Mar 2023, 06:39
I never got back to you.
Thank you so much for your guidance, it was totally helpful.
<3
