Transparent WEBP logo appears with black background in email template
kdim95
Post by kdim95 » 04 Apr 2023, 14:03
PHP Version: 8.2.4
Environment: Linux
The website logo appears with a black background if using a WEBP logo with transparent background.
Steps to reproduce:
1) Set a WEBP logo with transparent logo for the website
2) Have Aimeos send an order status email
The logo appears with a black background in the received email, specifically on Gmail.
It appears that the logo is converted into jpeg in the email, can PNG be used instead and what files do I need to change?
Re: Transparent WEBP logo appears with black background in email template
Post by aimeos » 11 Apr 2023, 06:31
kdim95 wrote: 04 Apr 2023, 14:03 The website logo appears with a black background if using a WEBP logo with transparent background.
Steps to reproduce:
Is that only a problem in Gmail or other web mail clients or e-mail clients too?
kdim95 wrote: 04 Apr 2023, 14:03 It appears that the logo is converted into jpeg in the email, can PNG be used instead and what files do I need to change?
If it's converted to JPEG, this is done by Gmail, so we don't have any influence on that. You can change the default image format to PNG so uploaded files are converted to PNG instead of WEBP but the files will be significantly bigger and the page load time can be much longer for users. To do that, add a configuration for "controller/common/media/preview/allowedtypes" and re-order the list of mime-types so PNG comes first here:
https://github.com/aimeos/aimeos-core/b ... #L600-L606
