Product with required subscription
IOU42
Post by IOU42 » 06 Apr 2023, 12:56
I have set up a product with an annual subscription. The product price is also set for a year.
As I want to use the subscription (Next Date field) to check is customer is allowed on member area, I also want to enforce the year interval, but now on the product page the interval can be chosen ('none' or 'a year').
- Is this possible to have a product automatically tied to an interval, and if yes how?
- Is there a better approach?
Kind regards, Marc
(Laravel 9, Aimeos 2022.10)
PS: I also gave it a try asking ChatGPT and it came up with the solution to add below to shop.php config file, but I assume this is incorrect?
'products' => [
    'product id number' => [
        'subscription' => [
            'enable' => true,
            'options' => [
                    'interval' => 'P1Y0M0W2D',
Re: Product with required subscription
Post by aimeos » 11 Apr 2023, 06:39
IOU42 wrote: 06 Apr 2023, 12:56 - Is this possible to have a product automatically tied to an interval, and if yes how?
Yes, configure the attribute of the type to be pre-selected so the "None" or "Please select" isn't rendered here:
https://github.com/aimeos/ai-client-htm ... #L164-L166
Docs: https://aimeos.org/docs/2022.x/config/c ... #preselect
IOU42 wrote: 06 Apr 2023, 12:56 PS: I also gave it a try asking ChatGPT and it came up with the solution to add below to shop.php config file, but I assume this is incorrect?
That's complete non-sense ;-)
IOU42
Post by IOU42 » 14 Apr 2023, 16:00
Thanks for your response again. I will go with that.
System info:
Running Aimeos Laravel: 2022.10
Laravel Framework 9.52
Almalinux
PHP 8.1
