Voucher and shipment costs presentation
nowrap
Post by nowrap » 08 Apr 2023, 18:54
we try to implement voucher coupon codes - as buyable gift cards or predefined coupon codes with a custom coupon provider (as mentioned here in the board)
We made some progress but we have a question regards the shipment cost presentation.
a) with applied coupon
b) normal payment
We like to add for the second coupon code row in the summary the reduced shipment costs amount instead of 0.00 Euros.
And if possible we like also to show the shipment costs with the subtotal. It should look like the "normal payment".
Can this be somehow configured or do we have to use a provider or custom template for this?
Regards
nowrap
Re: Voucher and shipment costs presentation
Post by aimeos » 11 Apr 2023, 07:37
You need to overwrite this template in your own extension:
https://github.com/aimeos/ai-client-htm ... detail.php
There, you can adapt displaying the rebate values for shipping costs according to your needs.
nowrap
Post by nowrap » 12 Apr 2023, 20:15
Thx alot for pointing me in the right direction.
