Override redirect base method.
santoshgarudi
Post by santoshgarudi » 12 Apr 2023, 08:03
Hi I am new to Aimeos,
https://github.com/aimeos/ai-admin-jqad ... e.php#L682
I want to override redirect() method, Is it possible and if yes how to do that.
Thanks in advance.
Re: Override redirect base method.
Post by aimeos » 17 Apr 2023, 08:23
Overwriting base classes is difficult because you would have to overwrite all classes which uses the base class instead.
What would you like to accomplish? Maybe we can add a macro to be able to customize the method if you can tell us what you would like to change.
