Page Roles and Permissions Aimeos
uouaks
Post by uouaks » 29 Apr 2023, 21:31
It is possible to make it support create/edit page, you will see the checkboxes for roles/permissions.
Example: https://i.stack.imgur.com/ZiqqF.png
Can you give any tips and practical advice so that our programmer can improve the functionality of the roles in aimeos himself?
Re: Page Roles and Permissions Aimeos
Post by aimeos » 01 May 2023, 06:22
Aimeos is currently not prepared to allow such fine-grained permissions as there are only roles and these roles are checked when accessing the panels. You can use further roles easily by adding more user groups and configuring them to allow access to certain panels. This may also be possible dynamically in a separate permission panel where you add the permissions for the roles to the site configuration, but you would have to adapt all JQAdm classes to check there if the user has the required role.
