Expose custom variable from decorator to the view
heural
Post by heural » 12 May 2023, 09:05
Hi Aimeos-Team,
how can I add custom var´s from an Frontend-Controller-Decorator class to the desired view?
Maybe from an Controller/Frontend/Basket-Decorator to the view (template) "client/html/basket/standard/body"?
Thank you!
Thanks a lot!
Re: Expose custom variable from decorator to the view
Post by aimeos » 14 May 2023, 10:28
You can't, because a frontend decorator doesn't have access to the view that is used in the HTML client. You can create a decorator for the HTML client that uses the frontend controller to retrieve data and assign that to the view.
heural
Post by heural » 23 May 2023, 07:14
Thank you, this was helpful!
Thanks a lot!
