Video upload
Sad
Video upload
Post by Sad » 29 Nov 2015, 17:18
Thanks.
Re: Video upload
Post by aimeos » 30 Nov 2015, 10:02
Sad wrote: I' d like to add a video as a digital product, also to add a video in catalog details component.
Adding a new subpart in the catalog detail component is relatively simple:
https://aimeos.org/docs/Developers/Html ... w_subparts
The media items are already available and can be retrieved in the view via
$this->detailProductItem->getRefItems( 'media', <type>, <list type> )
Should the video be available for download after purchasing it?
Sad
Re: Video upload
Post by Sad » 04 Dec 2015, 12:04
Thanks for a quick help.
Re: Video upload
Post by aimeos » 04 Dec 2015, 13:18
Sad wrote:Yes the video should be downloadable after it was purchased.
In that case, you have to place to video on your web space and add an attribute of type "Download" to the product, which contains the URL to the video in the "Code" field. The list type in the left panel (Associated attributes) must be "Hidden".
Sad wrote:But i dont understand, in the documentation it was writen that media can be photo and any kind of multimedia files... but for now as i can see, it is possible just to upload images. I need to customise for other types of media files?
Yes, you can add all kind of media files to products. Files other than images will be available in the (public) "Download" section of the product detail view (depending on the list type). If you want something else, you might need to add a special HTML subpart.
