Add an attribute with a decorator, but private?
kdim95
Post by kdim95 » 23 May 2023, 13:06
I'm attempting to add another attribute to the Review item, but have it private.
The attribute is supposed to store the user IP of the reviewer.
The problem is that the IP attribute is visible in the json response when searching for reviews with the jsonapi.
I attempted to add the " 'public' => false " key thinking that it would solve this problem, but it did not solve it.
private $attr = [
'ip' => [
'code' => 'ip',
'internalcode' => 'mrev."ip"',
'label' => 'Customer IP address',
'type' => 'string',
'internaltype' => \Aimeos\Base\DB\Statement\Base::PARAM_STR,
'public' => false,
Apparently this is being handled in the Review Item itself in the toArray() method.
What is the proper way to create custom attributes which are private?
Re: Add an attribute with a decorator, but private?
Post by aimeos » 25 May 2023, 06:32
At the moment, the only way is to overwrite the toArray() method in your own review item:
https://github.com/aimeos/aimeos-core/b ... #L304-L324
How to overwrite items and managers:
https://aimeos.org/docs/latest/models/e ... custom-way
kdim95
Post by kdim95 » 25 May 2023, 08:27
I did it a bit differently before you responded. Is this solution safe to work with?
I created a Review Manager Decorator, a custom Review Manager and a custom Review Item.
In the custom Review Item, I use unset() to remove the ip if its private.
This way I don't have to override the database manager insert, update, search configs.
Review Manager Decorator ( add IP attribute ):
<?php
namespace Aimeos\MShop\Review\Manager\Decorator;
class MyDecorator
    extends \Aimeos\MShop\Common\Manager\Decorator\Base
    implements \Aimeos\MShop\Common\Manager\Decorator\Iface
    private $attr = [
        'ip' => [
			'code' => 'ip',
			'type' => 'string',
            'public' => false,
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
	public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
Custom Review Item ( implement getIp(), setIp(), fromArray() and toArray() methods ):
<?php
namespace Aimeos\MShop\Review\Item;
class StandardCustom extends Standard
	public function getIp() : ?string
		return (string) $this->get( 'ip', 1 );
	public function setIp( ?string $value ) : \Aimeos\MShop\Common\Item\Iface
		return $this->set( 'ip', $value );
	public function fromArray( array &$list, bool $private = false ) : \Aimeos\MShop\Common\Item\Iface
		$item = parent::fromArray( $list, $private );
		foreach( $list as $key => $value )
			switch( $key )
				case 'ip': !$private ?: $item = $item->setIp( $value ); break;
				default: continue 2;
			unset( $list[$key] );
		return $item;
	public function toArray( bool $private = false ) : array
		$list = parent::toArray( $private );
		if( ! $private )
			unset( $list['ip'] );
		return $list;
Custom Review Manager ( implement createItemBase() to return custom Review Item ):
<?php
namespace Aimeos\MShop\Review\Manager;
    // Return custom review item
	protected function createItemBase( array $values = [] ) : \Aimeos\MShop\Review\Item\Iface
		return new \Aimeos\MShop\Review\Item\StandardCustom( $values );
Post by aimeos » 25 May 2023, 08:36
Yes, that's OK and the minimum code you need.
