Show all suppliers in filter dropdown
loeffe1
Post by loeffe1 » 30 May 2023, 14:55
Why are suppliers limited to 100 in the filter by
$items = $cntl->compare( '==', 'supplier.id', $view->param( 'f_supid', [] ) )
->slice( 0, 100 )->search()->replace( $items );
and is there any way to remove that limitation other than settings slice to a higher value in a custom class?
In a perfect setup, only suppliers that actually have products within the current category should be shown, is there any way to achieve this?
Re: Show all suppliers in filter dropdown
Post by aimeos » 31 May 2023, 08:44
It has been limited in the past to limit the data that's loaded and rendered in the page so avoid slow page loads.
Since 2022.10+, suppliers are loaded dynamically using a combobox and retrieving the suppliers via JS.
