How to limit text length of text product option
nowrap
Post by nowrap » 08 Jun 2023, 09:36
we configured our voucher selection product to have a text type option.
If i am right the rendering is done in this file:
templates/client/html/common/partials/attribute.php
And the resulting input-Field is this:
<input id="select-<?= $enc->attr( $key ) ?>" class="form-control" type="text" name="<?= $enc->attr( $this->formparam( ['b_prod', 0, 'attrcustid', $id] ) ) ?>">
Is it possible to limit the length of the text somehow?
Regards
nowrap
Re: How to limit text length of text product option
Post by aimeos » 10 Jun 2023, 06:20
Add a "maxlength" attribute to the input field in the template:
https://developer.mozilla.org/en-US/doc ... /maxlength
nowrap
Post by nowrap » 12 Jun 2023, 15:24
I know this attribute. Maybe my question wasn't precise enough.
I hoped, that aimeos had some kind of built-in mechanismn to limit input fields and present a counter on the field.
So that it is just a configuration.
We created a small javascript function for this now as a quick solution - adding the maxlength attribute to the html input, counting chars on keyup-event and changing the label field for the input.
