Locales -> Sites - Vue "options" list items appear for a split second and then disappear
kdim95
Post by kdim95 » 23 Jun 2023, 08:47
Laravel framework version: 10.13.5
Aimeos Laravel version: ~2023.04
PHP Version: 8.2.7
Environment: Linux
Here is what I'm experiencing:
1) Open up Locales -> Sites and select my site
2) The "options" on the right appear for a split second with their keys and values
3) The options disappear and I'm left with a list of empty fields
No errors are thrown in the console.
kdim95
Re: Locales -> Sites - Vue "options" list items appear for a split second and then disappear
Post by kdim95 » 23 Jun 2023, 23:27
I think that the problem is in this file:
ai-admin-jqadm/js/product.js
I updated it manually with the file from github and the problem was fixed.
The file is not updating with composer up.
Using "aimeos/ai-admin-jqadm": "~2023.04.x-dev" also fails.
It keeps downloading the wrong version of the file.
Post by aimeos » 26 Jun 2023, 07:00
Thank you for your investigations!
The problem was a query selector which wasn't specific enough and this has been fixed now. Please run "composer up" to get the latest version of the aimeos/ai-admin-jqadm extension.
kdim95
Post by kdim95 » 26 Jun 2023, 07:43
Thanks, it's fixed in ai-admin-jqadm 2023.04.8
