table mshop_index_price empty
RyadShaker
Post by RyadShaker » 02 Jul 2023, 12:46
Aimeos version 2023
PHP version 8
environment (Win)
I use the manager to add products with prices and when I add the product via cron
The table named mshop_index_price remains empty
my code
$context= $this->context();
$manager = \Aimeos\MShop::create( $context, "product" );
$item = $manager->createItem();
$item->fromArray( [
"product.id" => ""
"product.status" => ""
"product.type" => "select"
"product.datatype" => ""
"product.code" => "1"
"product.label" => "test"
], true );
$priceArray = [
'price.value' => '56740',
'price.lists.type' => 'default',
$priceManager = \Aimeos\MShop::create( $context, 'price );
foreach( $priceArray as $priceData )
$listItem = $manager->createListItem()->fromArray( $priceData );
$priceItem = $priceManager->createItem()->fromArray( $priceData );
$item->addListItem( 'price', $listItem, $priceItem );
$manager->saveItem( $item );
Re: table mshop_index_price empty
Post by aimeos » 04 Jul 2023, 11:30
Use the index manager instead of the product manager to save products. Then, they will be also added to the index tables automatically.
RyadShaker
Post by RyadShaker » 04 Jul 2023, 14:05
aimeos wrote: 04 Jul 2023, 11:30 Use the index manager instead of the product manager to save products. Then, they will be also added to the index tables automatically.
It gives me this error
Called unknown macro "createListItem" on class "Aimeos\MShop\Index\Manager\MySQL"
Post by aimeos » 04 Jul 2023, 14:29
Only for saving the product item, please!
RyadShaker
Post by RyadShaker » 04 Jul 2023, 14:37
aimeos wrote: 04 Jul 2023, 14:29 Only for saving the product item, please!
Thank you very much
