ai-cache class redis not found
dicko_luxo
Post by dicko_luxo » 11 Jul 2023, 14:37
Hello there..
Currently using:
Laravel 10.14.1
Aimeos 2023.07.1
ai-cache 2023.04.1
PHP 8.2
Ubuntu 22.04
I just installed a fresh Aimeos, and then followed by installing redis-server (added requirepass). And then I installed ai-cache ( https://github.com/aimeos/ai-cache ).
/config/shop.php :
        return [
            'resource' => [
                'cache' => [
                    'redis' => [
                        'scheme' => 'tcp',
                        'host' => '127.0.0.1',
                        'port' => 6379,
                        'password' => 'blahblah',
Afterwards, I checked through redis-cli if any keys are registered when I open a product/page in the site. Since I don't see any new keys added, I assume ai-cache is NOT working yet (please correct me if I'm wrong). So based on another thread here, I added the following in /config/shop.php:
        return [
            'madmin' => [
                'cache' => [
                    'manager' => [
                        'name' => 'redis',
Afterwards, when I run "php artisan aimeos:clear", I got the following error message:
LogicException
Class "\Aimeos\MAdmin\Cache\Manager\redis" not found
at vendor/aimeos/aimeos-core/src/Utils.php:20
So I have two questions:
1. Can anybody please let me know if I've made any mistake during installation process for ai-cache?
2. Can anybody tell me how to check if ai-cache is already working as intended?
Thanks in advance!
Re: ai-cache class redis not found
Post by aimeos » 12 Jul 2023, 11:28
First, you need a package version that matches the Aimeos version, i.e. "2023.07.x" in your case:
composer req aimeos/ai-cache:2023.07.*
Then, the name of the manager name must be in upper case:
        return [
            'madmin' => [
                'cache' => [
                    'manager' => [
                        'name' => 'Redis',
dicko_luxo
Post by dicko_luxo » 12 Jul 2023, 15:38
Thanks for the reply. I've tried doing these 2 points, and I got a different error message now when running "php artisan aimeos:clear" :
  Predis\Response\ServerException
  NOAUTH Authentication required.
  at vendor/predis/predis/src/Client.php:370
I assume this is because I use requirepass in redis.conf, so I try removing the password, and no more error message. BUT when I open shop page, or admin page, there are still no new keys created in the redis database. So I'm still not 100% sure if ai-cache is indeed working or not.
So my questions are:
1. If I want to add a password to redis, what config should I add?
2. How do I test if ai-cache is working properly?
Thanks in advance!
Post by aimeos » 13 Jul 2023, 05:53
The Predis library contains not much information about password authentication but it seems you need "username" AND "password": https://github.com/predis/predis#connecting-to-redis
