Custom delivery option
MartinKrál
Post by MartinKrál » 16 Jul 2023, 14:06
Hello!
I am implementing delivery that allows users to select a pickup point - every pickup point has it´s own ID which I am
able to store in an input field (I added this to delivery-body: <input type="hidden" id="zasilkovna_point_id" name="c_delivery[zasilkovna_point_id]" class="form-control"></input>).
My question is how can I access the value of this input field in push method of my delivery provider, eventually if I could also view it in order details from admin section.
Thank you,
Martin
Edit:
I am using following versions -
Laravel 10
PHP 8.1
Aimeos 2023.04
Re: Custom delivery option
Post by aimeos » 17 Jul 2023, 07:56
You can add the ID to the frontend using the getConfigFE() method and receive the selected value in the setConfigFE() method like in the supplier decorator:
https://github.com/aimeos/aimeos-core/b ... #L136-L188
