Class Input not found?
swpierce
Post by swpierce » 24 Dec 2015, 14:35
Fresh installs of composer (1.0-dev), Laravel (5.2.4), and Aimeos (1.2). Unable to open the storefront or the admin panels. Both result in this:
Admin error:
FatalErrorException in AdminController.php line 31:
Class 'Input' not found
Storefront error:
FatalErrorException in View.php line 35:
I've uninstalled everything and reinstalled twice. Same results each time.
swpierce
Re: Class Input not found?
Post by swpierce » 25 Dec 2015, 14:17
In addition to the above errors, if I do a clean install of 1.1 that works fine, change composer to
"require": {
        "aimeos/aimeos-laravel": "1.2",
and then run
composer update
, I get an error trying to open the admin panel. The problem is on line 44:
undefined jsFiles
Post by aimeos » 28 Dec 2015, 14:21
The Laravel 5.2 issue has been fixed: https://github.com/aimeos/aimeos-laravel/issues/19
swpierce wrote:I get an error trying to open the admin panel. The problem is on line 44:
undefined jsFiles
Can you post a bit more about this error? Do you have a stack trace?
