Product Image Ratio 1:1 not working proberly
Andy
Post by Andy » 01 Aug 2023, 11:04
Typo3 Version: 11.5.16
Aimeos Version: 22.7.2
PHP Version: 8.2
Hello everyone,
our product images uploaded in fileadmin are in a square format. The --ai-product-image-ratio value under Settings and Theme is set to 1/1. The cron job for rescaling the product images was also run.
If the product search is called up, the images are still in 3/4 format. After clicking on the product, the thumb is then displayed in list view in 1/1 format.
What do I miss to render the images in proper 1:1 ratio?
Thank you in advance.
Re: Product Image Ratio 1:1 not working proberly
Post by aimeos » 02 Aug 2023, 15:22
The CSS variable is only for displaying the image but you need to scale/crop the images according to the sizes required for your layout. You can define the sizes the preview images are generated for by overwriting this configuration:
https://github.com/aimeos/aimeos-core/b ... hp#L50-L66
Add the configuration to the Resources/Private/Config/controller.php file of you project-specific Aimeos extension instead of adding it via TypoScript because it needs to be available in the backend and the scheduler.
Andy
Post by Andy » 08 Aug 2023, 10:11
Thank you very much! It works as expected now.
unknow76616
Post by unknow76616 » 26 May 2024, 14:45
links not working
Post by aimeos » 27 May 2024, 07:27
The configuration has been moved to the media manager in 2024+:
https://github.com/aimeos/aimeos-core/b ... hp#L38-L64
