Subscription jobs
Justus
Subscription jobs
Post by Justus » 09 Aug 2023, 17:40
I have seen the following in the documentation
Once a day#
These jobs should be executed once a day (best at times of low traffic):
Start subscription period (start subscription period and add permissions if applicable)
Renew subscriptions (renew subscriptions on next date)
End subscription period (finish subscriptions and revoke permissions if applicable)
but what if I need to set permissions immediately after successful payment? The job will not work because it runs once a day.
Also it will not work correctly if the subscription lasts less than 1 day, for example 1 hour
I think after payment I need to trigger begin process manually
Re: Subscription jobs
Post by aimeos » 10 Aug 2023, 08:39
You can run the subscription jobs every minute if required
Justus
Post by Justus » 10 Aug 2023, 10:40
ok, but I will run the process manually after paying for the subscription, the user should not have to wait a while for the permissions
Justus
Post by Justus » 10 Aug 2023, 10:47
it also seems to me that I found a bug in the repay process for the Stripe provider, the price for the order will not take into account the price of the products, since only 'order/base/service' is set in the $ref for the getOrderBase method
if so, I can make a pull request with a fix
Post by aimeos » 12 Aug 2023, 09:40
If you think you've found a bug, please create an issue or an PR in the Github repository :-)
