Rendering product attirubutes on the product list board
abcdomino
Post by abcdomino » 17 Jan 2016, 10:19
Dear gentleman,
please advice what command should I add to the templates (catalog/list/items-body-default.html , catalog/detail/basic-body-default.html ) to render some product attributes? Please help
Best regards,
Dominik
Re: Rendering product attirubutes on the product list board
Post by aimeos » 17 Jan 2016, 11:43
abcdomino wrote:please advice what command should I add to the templates (catalog/list/items-body-default.html , catalog/detail/basic-body-default.html ) to render some product attributes?
You need to make sure the product attributes are fetched from the database:
https://aimeos.org/docs/Configuration/C ... st/domains
Then, the product items in the templates contain the attributes which can be fetched with
$product->getRefItrems( 'attribute' [, 'attr type'] [, 'list type'] );
