type error when installing custom aimeos laravel package
Laravel Framework: 10.19.0
Aimeos:~2023.07",
php: 8.1
OS: Ubuntu 22.04.1 LTS
Hey Aimeos team,
I am trying to install a custom extension for laravel aimeos on my local machine, and it is showing the following error when I try to access the shop url on local host.
Aimeos\Base\Config\Base::includeFile(): Return value must be of type array, int returned
This wasn't happening before I created the extension
These are the steps I followed to install the extension:
1 create the custom zip extension (istore-platform)
2 extract the zip into ./packages/istore-platform
3 change the minimum stability requirement in the composer json to dev
4 composer req aimeos-extensions/istore-platform
I had to do step 3 to get the package to install. These are the recommended steps in the Aimeos documentation. Am I missing something?
Any advice would be much appreciated!
Aimeos:~2023.07",
php: 8.1
Hey Aimeos team,
- response
- Screenshot 2023-08-18 104510.png (80.04 KiB) Viewed 20117 times
Re: type error when installing custom aimeos laravel package
The steps are OK and that works (usually).
Can you share the stack trace using the SHARE button at the top of the error page?
Check the ./config/ directory of your extension. There seems to be at least one .php file which doesn't contain:
<?php
return [
];Professional support and custom implementation are available at Aimeos.com
I solved the issue. The config files were all in the correct format. But when I unzipped the istore-platform directory it included zoneIdentifier files which were causing the problem. The page worked again when I deleted these files.
Thanks for your help!
