Empty list in aimeos backend typo3
pradeepsinh
Post by pradeepsinh » 08 Sep 2023, 16:46
TYPO3 Version 12.4.6
Aimeos Extension version 23.7.1
PHP Version 8.1
I need help with the Aimeos module in TYPO3.
The issue is when I try to add/select any supplier or any suggested products in the catalog, always shown the list is empty message. Screenshot: https://i.imgur.com/QmSXx0K.png
The supplier has already added to backend module. Screenshot: https://i.imgur.com/crViA62.png
But not shown in the list.
can you please help? How can I fix this?
Thanks!
Re: Empty list in aimeos backend typo3
Post by aimeos » 09 Sep 2023, 06:25
It works in our test setup without problems. Can you open the browser console and check the XHR/GraphQL request in the network tab?
pradeepsinh
Post by pradeepsinh » 11 Sep 2023, 07:31
Thanks for the quick replay.
I have checked in the network tab. But not show any error in the request.
Screenshot: https://i.imgur.com/MqcAoSk.png
But shows the error in the console.
Screenshot: https://i.imgur.com/1u8tPgS.png
I have also checked in the TYPO3 V12 Latest Fresh setup. but still, I face the same issue.
So can you please help me with this? How can I fix this issue?
Thanks!
Post by aimeos » 11 Sep 2023, 07:37
Can you check what's returned by the XHR requests? It seems to be a HTML document instead of the JSON response.
pradeepsinh
Post by pradeepsinh » 11 Sep 2023, 07:46
Yes, you are right.
The response is getting in the HTML Format
Screenshot: https://i.imgur.com/5cGfyFp.png
But I have no idea why the response is getting in the HTML format.
Can you please guide me on how can i fix this?
Thanks for the support
Post by aimeos » 14 Sep 2023, 09:57
Found the problem and a new version (23.7.2) has been released now :-)
pradeepsinh
Post by pradeepsinh » 15 Sep 2023, 05:16
Thank you for the quick support :)
