add new JSON API resouce
мужыковмужыков
Post by мужыковмужыков » 09 Sep 2023, 14:56
How can I add a new custom JSON API resource and use it?
Re: add new JSON API resouce
Post by aimeos » 10 Sep 2023, 08:32
If you have created a manager for a new data domain that contains only one table (and no lists or property table), then you can query the new resource directly over the JSON API. Just configure the new resource in the ./config/client.php file of your extension:
'jsonapi' => [
	'resources => [
		'mydomain' => 'mydomain'
See also: https://github.com/aimeos/ai-client-jso ... client.php
мужыковмужыков
Post by мужыковмужыков » 10 Sep 2023, 16:33
aimeos wrote: 10 Sep 2023, 08:32 If you have created a manager for a new data domain that contains only one table (and no lists or property table), then you can query the new resource directly over the JSON API. Just configure the new resource in the ./config/client.php file of your extension:
'jsonapi' => [
	'resources => [
I've added my own resource, but it works only with GET method, for other method I receive 419 Error (Page Expired). How I can fix that? I tried post method into class, but it still not working
Post by aimeos » 10 Sep 2023, 19:08
Send the CSRF token in the URL of the POST request like for the basket:
https://aimeos.org/docs/latest/frontend ... i/baskets/
