add new css/js files and override existing one
мужыковмужыков
Post by мужыковмужыков » 10 Sep 2023, 15:06
I've tried to add a new css and js file for the product page. I added it into /package/<theme>/themes/client/html/ and added them into manifest.jsb2 like this
        "name": "theme css",
        "file": "aimeos.css",
        "isDebug": true,
        "fileIncludes": [{
            "text": "aimeos.css",
            "path": "themes/client/html/"
, but it not added. And I've tried to override aimeos.css, which I put into /package/<theme>/themes/client/html/, but still used the default one. How I can add new files and customize an existing one
Re: add new css/js files and override existing one
Post by aimeos » 12 Sep 2023, 09:21
The manifest.jsb2 file is only for the admin backend. If you want to add own CSS/JS files in the frontend, you have to add them to the header.php file you overwrite in your own extension, e.g. for the catalog detail component:
https://github.com/aimeos/ai-client-htm ... hp#L74-L78
