Aimeos SaaS Admin Panel for Managing and Adding Sites
unknow76616
Post by unknow76616 » 11 Sep 2023, 15:20
I'm new to Aimeos and I'm not sure if there is a platform SaaS admin panel where I can manage and add sites. Can anyone help me with this?
environment: Linux
PHP version: 8
Re: Aimeos SaaS Admin Panel for Managing and Adding Sites
Post by aimeos » 12 Sep 2023, 09:18
You must have "super" privileges for managing sites in the Locale > Sites panel. You create a super user in the beginning when you install Aimeos.
unknow76616
Post by unknow76616 » 17 Sep 2023, 14:35
is this work for Laravel installed
I found this in the official documents:
php artisan aimeos:setup <site code> [<template site>]
I hope it never clones all site scripts (because they will be hard to maintain in the future)
Post by aimeos » 18 Sep 2023, 21:22
This creates all default records for new top level sites. It doesn't clone anything, just adds the records to the database.
