Error when addService.before is attached
kdim95
Post by kdim95 » 14 Sep 2023, 13:37
Laravel framework version: 10.16.1
Aimeos Laravel version: 2023.04.*
PHP Version: 8.2.8
Environment: Linux
I get the following exception when adding a service using the jsonapi:
exception: Error
file: /var/www/vhosts/<domain>/httpdocs/vendor/aimeos/aimeos-core/src/MShop/Order/Item/Base.php
line: 655
message: Call to a member function getPrice() on bool
I'm not even doing anything when the addService.before event occurs.
This is the structure of my plugin:
<?php
namespace Aimeos\MShop\Plugin\Provider\Order;
use Illuminate\Support\Facades\Http;
class MyPlugin
    extends \Aimeos\MShop\Plugin\Provider\Factory\Base
    implements \Aimeos\MShop\Plugin\Provider\Iface, \Aimeos\MShop\Plugin\Provider\Factory\Iface
    private $singleton;
     * Register plugin at publisher object
    public function register( \Aimeos\MW\Observer\Publisher\Iface $publisher ) : \Aimeos\MW\Observer\Listener\Iface
        $plugin = $this->object();
		$publisher->attach( $plugin, 'addService.before' );
        return $this;
    public function update( \Aimeos\MW\Observer\Publisher\Iface $basket, $event, $service = null )
        return true;
This is the request:
Request URL - https://<domain>/jsonapi/basket?id=default&related=service&relatedid=delivery&_token=<token>
Payload:
related: service
relatedid: delivery
_token: <token>
form data: {"data":[{"id":"service","attributes":{"service.id":"2"}}]}:
Re: Error when addService.before is attached
Post by aimeos » 15 Sep 2023, 06:07
Seems like you service has no price and the plugin is not responsible for the exception:
https://github.com/aimeos/aimeos-core/b ... 23-L655C30
kdim95
Post by kdim95 » 15 Sep 2023, 08:21
I've checked all of the services in the admin, they all have a price set.
I solved it, but I think that the documentation needs improvement, it doesn't specify this.
This is the line that causes the error.
$service = $this->notify( 'addService.before', $service );
The update() method of the plugin must return the service item, instead of "true", that's what causes the error "getPrice() on bool", because update() returned "true" instead of returning the service item.
kdim95
Post by kdim95 » 15 Sep 2023, 08:33
This documentation needs more updating:
https://aimeos.org/docs/2023.x/provider ... ate-plugin
Please look at the notification names here:
Aimeos\MShop\Order\Item\Base
Some notifications specified in the documentation do not exist, or are wrong.
For example "setService.before" and "setService.after", I think they should be "addService.before" and "addService.after".
Post by aimeos » 15 Sep 2023, 09:49
You are right and the articles has been updated now
