Multi-domains, custom theme and CSP
- ИванМаксимов
Hello!
ENV:
- laravel-aimeos 2023.07.01
- custom domains configuration
- installed one custom theme (named 't1')
- have 2 domains: shop.local and aimeos.local
- APP_URL=http://shop.local
- APP_DEBUG=false
- domain aimeos.local have default theme
- domain shop.local have t1 theme
Trouble:
On the site aimeos.local, the html header includes css/js files from the theme "t1" in an absolute path with the site name "shop.local" despite the fact that the theme for it is set to 'default' and CSP blocks load these files
File vendor/aimeos/aimeos-laravel/views/base.blade.php - is default file from installation just added comment around @yield('aimeos_header'):
After change theme i also run artisan aimeos:clear, view:clear, optimize commands but theme still unchanged - t1.
What else needs to be done for the theme change to take effect?
ENV:
- APP_DEBUG=false
Trouble:
<!-- default theme begin aimeos_header -->
<!-- default theme end aimeos_header -->After change theme i also run artisan aimeos:clear, view:clear, optimize commands but theme still unchanged - t1.
- Снимок экрана 2023-09-15 в 13.04.37.jpg (140.27 KiB) Viewed 24876 times
- Снимок экрана 2023-09-15 в 13.04.17.jpg (210.27 KiB) Viewed 24876 times
- Снимок экрана 2023-09-15 в 11.36.56.png (177.59 KiB) Viewed 24876 times
- ИванМаксимов
Re: Multi-domains, custom theme and CSP
I found where generates url to css files:
vendor/aimeos/aimeos-base/src/View/Helper/Content/Standard.php:68
\Aimeos\Base\View\Helper\Content\Standard::baseurl
Here code:
But $this->view()->config() gets static value from cached config file instead get asset() dynamic value based on Request
Here code:
if( !isset( $this->baseurls[$fsname] ) ) {
$this->baseurls[$fsname] = rtrim( $this->view()->config( 'resource/' . $fsname . '/baseurl', '' ), '/' );
return $this->baseurls[$fsname];
}Code: Select all
'fs-theme' => [
'adapter' => 'Standard',
'tempdir' => storage_path ( 'tmp' ),
'basedir' => public_path ( 'vendor/shop/themes' ),
'baseurl' => rtrim ( env ( 'ASSET_URL', PHP_SAPI == 'cli' ? env ( 'APP_URL' ) : '' ), '/' ) . '/vendor/shop/themes',
],Re: Multi-domains, custom theme and CSP
If you have multiple domains only use this as basedir value:ИванМаксимов wrote: 15 Sep 2023, 10:29Code: Select all
'fs-theme' => [ 'adapter' => 'Standard', 'tempdir' => storage_path ( 'tmp' ), 'basedir' => public_path ( 'vendor/shop/themes' ), 'baseurl' => rtrim ( env ( 'ASSET_URL', PHP_SAPI == 'cli' ? env ( 'APP_URL' ) : '' ), '/' ) . '/vendor/shop/themes', ],
'baseurl' => '/vendor/shop/themes'
- ИванМаксимов
Yes, it is work!
I think you need include this into your documentation ...
The best option is to not set the ASSET_URL in your .env file like in the example that is shipped with Aimeos:
https://github.com/aimeos/aimeos/blob/m ... example#L7
We've added a tip in the section about adapting the routing:
https://aimeos.org/docs/latest/laravel/ ... he-routing
