How to init full process to create a site?
OleksiiFedorenko
Post by OleksiiFedorenko » 18 Sep 2023, 13:26
Can I create a site by using built-in tools, without using
artisan aimeos:setup <site code>
Re: How to init full process to create a site?
Post by aimeos » 18 Sep 2023, 21:35
You can use the code from the command in your own controller for example:
https://github.com/aimeos/aimeos-larave ... hp#L57-L65
OleksiiFedorenko
Post by OleksiiFedorenko » 19 Sep 2023, 10:56
And how can I get context if I use
Artisan::call("aimeos:setup $site");
