Attribute types translation in admin
akropivko
Post by akropivko » 23 Sep 2023, 13:57
Please provide the way to translate the attribute types on product details, see the screenshot
Version - 2023.07
Integration - Laravel
System - Windows10
Re: Attribute types translation in admin
Post by aimeos » 24 Sep 2023, 20:46
You can translate the attribute types in your ./config/shop.php or using a PO/MO file in the "client/code" domain:
https://github.com/aimeos/ai-client-htm ... y.php#L387
See also: https://aimeos.org/docs/latest/laravel/ ... anslations
akropivko
Post by akropivko » 27 Sep 2023, 19:10
aimeos wrote: 24 Sep 2023, 20:46 You can translate the attribute types in your ./config/shop.php
Could you prodide me with the path for the translation in ./config/shop.php? I tried several options, but with no result
Post by aimeos » 29 Sep 2023, 06:53
'i18n' => [
	'en' => [
		'client/code' => [
			'Material_fasadu' => ['Facade material']
Starting with 2023.10 LTS, you will be able to add translations directly to the type items in the Aimeos backend.
akropivko
Post by akropivko » 29 Sep 2023, 10:42
aimeos wrote: 29 Sep 2023, 06:53 'i18n' => [
'en' => [
'client/code' => [
It works good for the frontend, but it still doesn't work for the admin part, see the screenshort:
aimeos wrote: 29 Sep 2023, 06:53 Starting with 2023.10 LTS, you will be able to add translations directly to the type items in the Aimeos backend.
That's great, thanks
Post by aimeos » 29 Sep 2023, 10:45
The backend attribute codes won't be translated, only in the frontend
