Aimeos filtering attributes and categories
Doku
Post by Doku » 27 Sep 2023, 08:04
We are using:
- TYPO3 v11
- aimeos dist 22.10.1
- aimeos 22.10.9
We have built multiple shop with aimeos in typo3 (fairly standard), the only catch is a relative large amount of products and
attributes (~15,000 products, ~ 10,000 attributes | >50,000 products, ~ 50,000 attributes).
To filter the products, we use a combination of categories and attributes.
Each shop has 3 parent categories and ~30-50 child categories, limiting the amount of attributes the shop has to work with.
To display more attributes on the loss of performance, we use following settings:
# More filtered produkts in the FE
plugin.tx_aimeos.settings.mshop.common.manager.aggregate.limit = 1000000000
# More filtering attributes in the FE
plugin.tx_aimeos.settings.controller.frontend.common.max-size = 99999
These seem to have a max way below, 1000000000 and 99999.
1)
Still, aimeos won't show all attributes or just don't get the counts right when filtering attributes. (e.g. when filtering attribute [A_1 = a], A_2 -> b shows 2 products whilst there is no product with combination [A_1 = a, A_2 = b]).
2)
Furthermore, when selecting the first attributes-filter the categories is lost even using following setting:
plugin.tx_aimeos.settings.client.html.catalog.filter.tree.force-search = 1
<input type="hidden" name="<?= $enc->attr( $this->formparam( ['f_catid'] ) ) ?>" value="<?= $enc->attr( $this->param( f_catid' ) ) ?>">
The above input is displayed and filled with right values (before filtering the first attribute).
Related:
Filter attributes within the currect category
help-f15/filtering-when-in-categorie-t489.html
https://github.com/aimeos/aimeos-core/c ... ccf90a7f82
Re: Aimeos filtering attributes and categories
Post by aimeos » 28 Sep 2023, 06:33
Doku wrote: 27 Sep 2023, 08:04
There's a hard limit in the SQL statement of 10,000 for counting, so you have to overwrite it too:
https://github.com/aimeos/aimeos-core/b ... ex.php#L79
Doku wrote: 27 Sep 2023, 08:04 Furthermore, when selecting the first attributes-filter the categories is lost even using following setting:
This should work because of:
- https://github.com/aimeos/ai-client-htm ... hp#L64-L72
- https://github.com/aimeos/ai-client-htm ... d.php#L269
Can you check if the f_catid value is used in the catalog/lists component?
Doku
Post by Doku » 04 Oct 2023, 08:37
aimeos wrote: 28 Sep 2023, 06:33 This should work because of:
<input type="hidden" name="ai[f_catid]" value="25">
<input type="hidden" name="ai[f_name]" value="ALPINA">
These are set correctly. But once I apply a filter based on an attribute, the category information is lost.
(The URL seems to miss this Information as well: [...]?ai%5Bf_attrid%5D%5B%5D=1452)
<input type="hidden" name="ai[f_catid]" value>
<input type="hidden" name="ai[f_name]" value>
Post by aimeos » 05 Oct 2023, 09:34
Do you use catalog/tree and catalog/attribute as separately plugins instead of the catalog/filter plugin? The catalog/attribute template doesn't contain the f_catid and f_name values as hidden input values and thus, the information is lost. You can add the hidden inputs in a copy of your catalog/attribute-body.php template to make it work for your case.
