Aimeos logs on 500 error
OleksiiFedorenko
Post by OleksiiFedorenko » 30 Sep 2023, 10:49
Greetings, I have error 500 when I use aimeos jsonapi. Error message said "An error occured and has been added to the logs". If I check madmin_log there is nothing. Where are api logs? Maybe I need to turn on verbose or something?
Re: Aimeos logs on 500 error
Post by aimeos » 02 Oct 2023, 12:46
You can use this configuration in your ./config/shop.php to add the error details to the JSON:API output:
'client' => [
	'jsonapi' => [
		'debug' => 1
See: https://aimeos.org/docs/2023.x/frontend ... r-handling
