I am unable to import test products using cronjobs
kuro
Post by kuro » 10 Oct 2023, 09:29
Hi all!
To import products, I used the instructions at this link: https://aimeos.org/docs/2023.x/cronjobs ... sv-import/
I also want to display my settings file(D:\myshop\config\shop.php):
	'client' => [
		'html' => [
			'basket' => [
				'cache' => [
					// 'enable' => false, // Disable basket content caching for development
			'common' => [
				'cache' => [
					// 'force' => true // enforce caching for logged in users
			'catalog' => [
				'lists' => [
					'basket-add' => true, // shows add to basket in list views
					// 'infinite-scroll' => true, // load more products in list view
					// 'size' => 48, // number of products per page
				'selection' => [
					'type' => [// how variant attributes are displayed
						'color' => 'radio',
						'length' => 'radio',
						'width' => 'radio',
	'controller' => [
		'frontend' => [
			'catalog' => [
				'levels-always' => 3 // number of category levels for mega menu
		'jobs' => [
			'product' => [
				'import' => [
					'csv' =>  [
						'skip-lines' => 1 ,
						'mapping' => [
							'item' => [
								1 => 'product.label', // UTF-8 encoded text, also used as product name
								2 => 'product.type', // type of the product, e.g. "default" or "selection"
								3 => 'product.status', // enabled (1) or disabled (0)
							'text' => [
								6 => 'text.type', // e.g. "long" for long description
								7 => 'text.content', // UTF-8 encoded text
							'media' => [
								8 => 'media.url', // relative URL of the product image on the server
							'price' => [
								9 => 'price.currencyid', // three letter ISO currency code
								10 => 'price.quantity', // the quantity the price (for block pricing)
								11 => 'price.value', // price with decimals separated by a dot
								12 => 'price.taxrate', // tax rate with decimals separated by a dot
							'attribute' => [
								13 => 'attribute.code', // code of an attribute, will be created if not exists
								14 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
							'product' => [
								15 => 'product.code', // e.g. EAN code of another product
								16 => 'product.lists.type', // e.g. "suggestion" for suggested product
							'property' => [
								17 => 'product.property.value', // arbitrary value for the corresponding type
								18 => 'product.property.type', // e.g. "package-weight"
							'catalog' => [
								19 => 'catalog.code', // e.g. Unique category code
								20 => 'catalog.lists.type', // e.g. "promotion" for top seller products
i am a new stater for php and aimeos,so i only changed the shop.php file above, i put the csv file in "D:\myshop\storage\import\product\products-import-example.csv", i start the server in D:\myshop\ using 'php artisan serve',then i start another cmd php artisan aimeos:jobs "product/csv/import job controller",and got some errors,please check the Attachments.
2. i want to add a catagory named blog to the nav and put some articles on that, where can i do that?
3. i want to replace the product page's price to an Inquiry form,, where can i do that?
4.i want to remove the basket and add to basket button, where can i do that?
please help me .
Versions:
aimeos - 2023.07.2(https://github.com/aimeos/aimeos)
Apache/2.4.56 (Win64) OpenSSL/1.1.1t PHP/8.2.4
mysqlnd 8.2.4
Windows 11
Re: I am unable to import test products using cronjobs
Post by aimeos » 10 Oct 2023, 09:43
Wrong command, you must use:
php artisan aimeos:jobs product/csv/import
kuro
Post by kuro » 11 Oct 2023, 01:08
aimeos wrote: 10 Oct 2023, 09:43 Wrong command, you must use:
LogicException ,see the attachment
Versions:
mysqlnd 8.2.4
Windows 11
Post by aimeos » 11 Oct 2023, 06:38
Sorry it's:
php artisan aimeos:jobs product/import/csv
See: https://aimeos.org/docs/latest/laravel/ ... once-a-day
kuro
Post by kuro » 11 Oct 2023, 06:46
aimeos wrote: 11 Oct 2023, 06:38 Sorry it's:
Symfony\Component\Mailer\Exception\TransportException ,
see the attachment
Post by aimeos » 11 Oct 2023, 06:51
There's an error when importing the CSV file and you didn't configure the mail server in your .env file.
For import errors, you should have a look into the Log panel of the admin backend.
beenzu
Post by beenzu » 27 Feb 2024, 18:24
win 10/php8.1.2/Aimeos:2023.10.x
I am experiencing the same error after running the cmd :
php artisan aimeos:jobs product/csv/import.
Did you resolve the resolve the error? The logs show the same error
