How to access user groups from a laravel controller?
shainanand
Post by shainanand » 16 Oct 2023, 15:07
I am trying to get user groups from Laravel Controller. Is there any sample code that I can refer to?
Re: How to access user groups from a laravel controller?
Post by aimeos » 18 Oct 2023, 07:10
What do you want them for?
For access control use the group codes like this (https://laravel.com/docs/10.x/authoriza ... er-helpers):
$this->authorize( 'admin', [get_class($this), ['admin', 'editor']] );
That works because of these lines: https://github.com/aimeos/aimeos-larave ... entication
The group IDs are available in the context:
$groupIds = app( 'aimeos.context' )->get()->groups()
You can get the user group items like this:
$user = Aimeos\Shop\Facades\Customer::uses( ['customer/group'] )->get()
$groups = $user->getRefItems( 'customer/group' );
Alternatively using the customer frontend controller:
$user = \Aimeos\Controller\Frontend::create( app( 'aimeos.context' )->get(), 'customer' )
	->uses( ['customer/group'] )->get()
shainanand
Post by shainanand » 21 Oct 2023, 15:24
Thank you
shainanand
Post by shainanand » 17 Nov 2023, 12:04
Tried the code today and groups was returning empty. This is the printed $user variable. Any missing configuration?
Image 26.png (22.67 KiB) Viewed 27748 times
Post by aimeos » 20 Nov 2023, 16:59
Which of the alternatives did you use?
shainanand
Post by shainanand » 21 Nov 2023, 10:49
May I know what is meant by alternatives ?
Post by aimeos » 22 Nov 2023, 12:51
Which of those lines did you use?
aimeos wrote: 18 Oct 2023, 07:10 The group IDs are available in the context:
shainanand
Post by shainanand » 22 Nov 2023, 14:07
I used this one
Post by aimeos » 24 Nov 2023, 07:09
Remember that you must be logged in to retrieve the user and his groups.
According to your screenshot, this isn't the case.
