csv import: assign product to 1..n categories
columbo
Post by columbo » 24 Oct 2023, 17:13
a product should be listed in one or multiple (sub-)categories. The number of (sub-)categories is not defined yet -> listing a product in 1, 2 or n subcategories.
According to https://aimeos.org/docs/2023.x/cronjobs ... sv-import/ we have to define 1..n 'catalog.code' mappings in shop.php - correct?
Is there also an option to define one 'catalog.code' in shop.php mapping and add additonal categories (catalog.code) with new-line in csv?
Thank you!
Re: csv import: assign product to 1..n categories
Post by aimeos » 26 Oct 2023, 07:34
You can add several category codes in one field separated by new lines, e.g.:
,"cat-1
cat-2
cat-3",
