Does aimeos support async replicas?
andy.jh92
Post by andy.jh92 » 27 Oct 2023, 08:57
Hi!
Does aimeos support async replicas all over the world for better global low latency?
Thanks!
Regards, Andy
Re: Does aimeos support async replicas?
Post by aimeos » 27 Oct 2023, 17:27
That's mainly a storage issue. If you use ElasticSearch (supported by the ai-elastic extension) for storing products, you can build a distributed e-commerce application with very fast response times all over the world.
The main problem to get things even faster is the relational database for storing the non-product data. Aimeos supports Yugabyte as distributed RDBMS but it needs some special care during setup because it is missing one feature for complete database schema updates yet.
