how to overwrite translation files for jobs
akropivko
Post by akropivko » 27 Oct 2023, 13:32
I'd like to overwrite translation files from vendor/aimeos/ai-controller-jobs/i18n.
What folder in my extention I should use to do this?
"aimeos/aimeos-laravel": "2023.10.x-dev",
thanks
Re: how to overwrite translation files for jobs
Post by aimeos » 30 Oct 2023, 11:47
Place the .po file in the "i18n" directory of your extension and generate the MO file in the same directory:
https://aimeos.org/docs/latest/develope ... s/#gettext
akropivko
Post by akropivko » 05 Nov 2023, 16:22
There are multiple i18n directories with .po files, such as:
  • vendor/aimeos/ai-controller-jobs/i18n/
  • vendor/aimeos/ai-client-html/i18n
  • vendor/aimeos/ai-client-html/i18n/code
Should I use a single .po (and .mo) file in the "i18n" directory of my extension to override all of these files?
Post by aimeos » 06 Nov 2023, 09:00
Yes, you need only one file which must contain all translations from all translation domains.
