Is it possible to make each product in the basket to be individual order?
shainanand
Hi Aimeos, need your expertise in this requirement. I would like to make each product in the basket to be placed as individual order instead of putting multiple products in each order. Is this possible right now? If not, what would be the best approach to achieve this?
Re: Is it possible to make each product in the basket to be individual order?
That's difficult because the payment handling afterwards expects only one order. If payment gateways aren't used, you could extend the order manager to create several orders in its save() method instead of just one.
Why do you want to split up the order per product? Maybe there's a better way to achieve your goal if you can describe your requirements.
shainanand
Our requirement is to have different shipping cost for each product and we want to track each product individually. So we are thinking of splitting the products in the baskets to multiple orders. Any other way to achieve this?
That's achievable much simpler. Write a (delivery) service decorator that calculates the shipping for each product and sets that as costs in the order product item. Add the tracking information as order product attributes.
See: https://aimeos.org/docs/latest/providers/service/
shainanand
Thanks, that really help. On continuation to this, since we have multiple shipping service, how can I add one more delivery service into this object? Currently it has only one.
![Image]()
- Image 6.png (8.81 KiB) Viewed 10005 times
shainanand
I have managed to create multiple delivery service array but when saving the basket delivery services, it is saving both th delivery service with same code and name. However before saving my delivery service had different code and name.
![Image]()
- Image 9.png (6.57 KiB) Viewed 9978 times
The service options with the different names must be created in the backend. If you just use one service item and set different values, they will be overwritten.
shainanand
But I noticed that before the processPayment(), the delivery items are saved with different codes. But after that, the codes got overwritten. Could you please help to point our where exactly the overwriting takes place?
