Installation and upgrade fails
goerch
Post by goerch » 19 Feb 2016, 20:17
I have a problem installing the new Version 16.1.2. On my local system the upgrade fails from 2.4.3, testing on a new typo3 - installation (not local) the installation 16.1.2 fails. The database update - script stopped with an error "failed: SQLSTATE[HY000]: General error: 1267 Illegal mix of collations (latin1_swedish_ci,IMPLICIT) and (latin1_german1_ci,IMPLICIT) for operation '='" and following a list of items and scripts from #0 to #21
like #0 "/mnt/webf/d2/64/5287964/htdocs/xxx/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Base.php(914): Aimeos\MW\DB\Statement\PDO\Simple->execute()"
Testing system: T3 6.2.15, PHP 5.5.32, MySQL 5.5.45
What can i do? The idea was to upgrade from 2.4.3, because i need a tax feature (prices without tax) for a b2b shop.
Re: Installation and upgrade fails
Post by aimeos » 20 Feb 2016, 00:30
Can you please check the collation of your fe_users and the static info tables? These are the only ones that Aimeos is joining in certain queries. I guess the collation is different from the Aimeos mshop/madmin tables (utf8_general_ci).
goerch
Post by goerch » 22 Feb 2016, 10:58
Thank you, it seems to be the problem. Changing the collation to utf8_general_ci in the table "fe_user" AND the fields in "fe_user" solve the problem in one test installation. On local installation i can't see the backend. This could maybe a caching problem, the update script goes well, but the backend module shows only a blank page. I am looking for a solution and then i will report.
Post by aimeos » 22 Feb 2016, 11:18
goerch wrote:On local installation i can't see the backend. This could maybe a caching problem, the update script goes well, but the backend module shows only a blank page. I am looking for a solution and then i will report.
Can you please have a look into the error log of your web server if there's something wrong?
You should also check in the web console of your browser if there's any Javascript error.
goerch
Post by goerch » 24 Feb 2016, 11:04
So, the local installation: Installation is ok, but starting aimeos backend displays the following error: "Parse error: syntax error, unexpected 'class' (T_CLASS), expecting identifier (T_STRING) or variable (T_VARIABLE) or '{' or '$' in xxx\typo3conf\ext\aimeos\Resources\Libraries\zendframework\zend-servicemanager\src\ServiceManager.php on line 281"
Local system: T3 6.2.9, XAMPP on Windows, PHP 5.4.27, MySQL 5.5.36
Post by aimeos » 24 Feb 2016, 13:58
Unfortunately, the used Zend component pushed the required PHP version up to 5.5. We already replaced Zend in the latest code base with a low resource implementation which only requires PHP 5.4. You can give it a try by downloading it from this URL:
https://aimeos.org/fileadmin/download/a ... 2.0-b1.zip
goerch
Post by goerch » 24 Feb 2016, 14:19
Thank you i will try it.
But the next error is installing Version 2.4.3: Update-Script breaks with
"Executing statement "CREATE INDEX "idx_t3feuad_refid" ON "fe_users_address" ("refid");
" failed: SQLSTATE[42000]: Syntax error or access violation: 1072 Key column 'refid' doesn't exist in table".
T3 6.2.9
goerch
Post by goerch » 24 Feb 2016, 14:36
First report: Version 6.2.0 b works fine for me. No problems with installation. This solves also the problem with the update script.
