Translate PO file for admin
AleksandarJovanovic
Post by AleksandarJovanovic » 09 Dec 2023, 16:54
Aimeos version 2023.10
Php: 8.1
Linux
Dear,
I try to translate po file to edit some word on serbian language.
I save that file in poeditor but nothing change in admin panel.
When i look in file sr.po the changes is saved.
Best regards, Alex.
Re: Translate PO file for admin
Post by aimeos » 10 Dec 2023, 10:49
PO files have to be compiled into MO files which are use for translation lookup:
https://aimeos.org/docs/latest/developer/translations/
If you want to fix a translation because it's wrong, then please do it in Transifex. Then, it will be available in all future releases:
https://app.transifex.com/aimeos/
AleksandarJovanovic
Post by AleksandarJovanovic » 10 Dec 2023, 16:02
Dear,
I translete in poedit and save file than i compile in to .mo file and replace file. Butn nothing change on admin dasboard.
Did i miss something?
I read documentation and example of gettext and seems i doing well.
Screenshot is in attachments.
Alex
Screenshot from 2023-12-10 16-58-31.png (142.15 KiB) Viewed 7566 times
Screenshot from 2023-12-10 16-58-57.png (182.64 KiB) Viewed 7566 times
Post by aimeos » 12 Dec 2023, 12:32
The .po file and the compiled MO binary must be in the ./i18n/ directory of your own project-specific Aimeos extension, e.g. "./packages/myext/i18n/sr"
AleksandarJovanovic
Post by AleksandarJovanovic » 15 Dec 2023, 18:33
Thanks, work like a charm 😇
Best regards
