Help needed on Stripe Payment for Marketplace integration
shainanand
Hi, my client purchased Stripe Payment for Marketplace plugin. I have enabled the Payment Service by adding Stripe Marketplace, added necessary api keys. So during the order, the payment works fine. But I want to know the following items?
1. Is there any integration documents for Stripe Payment for Marketplace?
2. How I can use the Stripe Connect features like linking a seller to the order payment so that from Stripe Connect dashboard I would know the payment is linked to which seller?
3. In the Settings page, there is Stripe tab. But even after entering Stripe APis in Service page, it still shows "No Stripe API key configured for marketplace".
Any assistance would be helpful.
- stripe1.png (49.44 KiB) Viewed 5334 times
Re: Help needed on Stripe Payment for Marketplace integration
There are README.md files in all packages and you should consult this file first.
If it doesn't answer your questions, contact the company support.
shainanand
Hi, I have setup accordingly to the readme file. However, I am not sure about one thing. When I make a payment, in Stripe dashboard I cannot see to which connected account, the payment is linked to. Anything I missed to setup?
shainanand
Hi @aimeos, Is there any option in stripe marketplace plugin to enable embedded onboarding? Right now Aimeos is directing users to Stripe website for onboarding?
